jstpsgthru
 - May 8, 2016
 - 3
 - 15
The service manual states shows two drive systems for this product. I have the "Hydrogear" version. There is also an IVT transmission, but it only has one drive belt, as well.
There is a "caution" that using a non-OEM belt may prevent the de-clutching mechanism from working properly WHEN THE BRAKES ARE APPLIED (emphasis is mine.)
So, if there was a difference of .2" that makes the belt too tight when new, is it likely that small a difference will fade and possibly correct the problem? I'm thinking maybe.
BTW, I think a service shop would probably want to sell me more stuff and labor, if the tension arm pivot was loose.
Thanks to everyone that has offered help. I am going to ride for a while and see if there is improvement. Hopefully, I won't break anything.
