Help top starter bolt on BS v-twin installation
guest2
That is what i could find, hope I can get it tight enough. I should know tomorrow. Thanks for all the help. Sometimes you are just to close to the problem to see the solution. thanks again. It should work.
It worked great . thanks to all who offered help.
KennyV
Some times very special 'common' tools are needed because of close fit..
Nothing fits like a Snap On thin wall socket...
Just a silly question.. What did you use to remove it in the first place...? :smile:KennyV
