Ok, so I pulled the deck off again and removed the tensioner plate. Turns out there is nothing wrong with the tensioner pin bushings. They measure about 1.003" just enough clearance for a 1.000" pin. It's the pins that are bad, real bad. The plate has (2) 1" holes , the pins are set in place and welded on the back side. Turns out that instead of hardening the pins and letting the easily replaceable bushings take the wear, the awesome company engineers, used soft pins and hardened the bushings. So instead of just replacing for 4 bushings for $25, you get to replace the weldment at the insane cost of $113 plus shipping to $191 (depending on what vendor you choose) for this " weldment ". I can see guaranteed money for Snapper for their parts vendors on replacement parts this way. I'd happily manufacturer this weldment for $50 a pop , all day long.
As you can see, the tops and bottoms of these pins are WAYYYYY undersized. After looking at the cost of this weldment, I figure I could just machine the 2 new pins and replace them myself in about 1½ worth of time and 6" of bar stock.. So I ground the welds off the original pins and knocked them out, machined a couple of new pins, and welded them back in place. No slop now, so the whole deck has now been rebuilt. Every bearing is new or as new, all pulleys are in great shape, one is new, deck belt is brand new and as soon as I get the new drive belt in the mail Tuesday. I'm gonna cross my fingers and hope for the best. Everything has been either rebuilt or replaced with new parts. There is nothing else to replace to make this belt stay in place.
