I have 2 of these Canadian tire /Lawn boys. The first one my dad bought in 1982 ( I have the original mastercraft manual) . A few years ago I found an identical one in the trash so I took it home thinking it would be good for parts....added some gas and a plug and it started up....so now have two that run. The only problem is that they have a steel deck and my first one had some holes that I had to patch. Found another old 1979 Lawn boy and thought I could use its magnesium deck but motor will not fit on deck.....engine is almost identical except for shroud and gas tank.
Long story short I now have 3 of these 2 strokers and they run great as long as you clean the carb and use good fresh gas and oil mix.
The manual states the needle seat combo is # 681741 but I have used toro number 92-9697 which is the replacement.
Most of the time they do not need a new needle and seat just a good cleaning.
This you tube vid shows your exact carb and how to clean it....
Carburetor Cleaning on Lawnboy Lawnmower - YouTube
My first 1982 still has all original carb parts but it does need cleaning especially if you use regular gas that has ethanol.
