WhyZed
Hello everyone,
As the tittle states, I have no idea what year, model etc this mower is that I found on the roadside. I have not seen another like it and I have looked.
When I type in the serial or model # of the chassis or the # stamped on the motor, I get nothing..
Serial # - 60-1618-2 (I have the link to the manual so I do know 'if I'm reading it correctly' its 1982-1985?)
Model # - 1059440
Motor # - D1-2 609408
Any help would be greatly appreciated.
It was not running when I got it home.
-Gas tank and carb were fully gummed with goop.
-Screen in gas tank plugged.
-Float needle valve leak bad.
-Float out of spec.
-Muffler totally plugged with carbon (cheap oil I'd guess). Literally totally plugged, zero exhaust!
-Governor out of adjustment (previous owns attempt to make it run). When I cleaned out the packed muffle & started it up, it rev'd to the moon.
-Hand brushed paint :confused2:
She runs now and will be supreme when I get the new needle valve & seat.
High compression - very low blow by the rings, no sign of dirt, rust or water in the crank. Looks like a solid low hrs motor.
Overall a good find, and a good new home.
It is so light to throw around. I'm watering the lawn tonight, hopefully I'll be able to do more than start er up and take a sip of brew!
Model # - 1059440
-Float out of spec.
