Сan you just write a model of the best chainsaw or several options.
Thank you!:smile:
The whole point is there is no such thing as a best chainsaw.
There are quality chainsaws that are particularly suited for a particular purpose.
So we would need to know a whole lot of things to give you a valid opinion.
As an example, I just fixed a top handle, one handed arbourists limbing saw for a 66 year old customer , only to find he no longer had the strength to start the saw safely.
And down here this was a top shelf $ 2000 professional saw.
For him the "best" saw was a $ 600 Husqvarna with easy start and a 12" narrow kerf bar with sprocket tip and skip tooth anti kick back chain.
The German & Japanese made Sthils are excellent saws, the USA made ones reasonable, the Brazil made ones OK and the Italian or Chinese made ones best avoided.
It is not like picking the best can of beans, chain saws are a very complicated product.
I for one would put Shindawa above Stihl followed by Echo the Husqvarna at the professional level saws
When you get to homeowner grade then some Husqvarna's would rank second.
For long life you need a saw with 2 piston rings, it makes a very big difference to both the saw & the price .
Then there are things like heated handles if the was is likely to be used a lot in winter as frostbite when using a chainsaw has cost almost as many fingers as careless use.
Then there is the use, faster chain speeds of Husqvarna's suit soft woods like spruce fur & pine where as greater torque of the Stihls & Shindawas are more suitible for oaks & euculupts.
If hubby has short arms then a soft start is an important feature.
Then there is weight to consider.
If he is going to be cutting 20 chords of fire wood a season he will need a different type of saw to the one he would be using to fell the tress on your new block.
So start with his age , height & physical condition.
Next what is he going to be doing with the saw
Then what sort of budget you have.
His level of mechanical skills & the proximity of different dealers.
Armed with all of this information then there are plenty of people here with the skills & experience to submit several saws he is likely to be happy with.
My landlord can not use the Stihl that my wife can use blindfolded
My wife can start the monster 070 easily but has difficulty with the 045 which weighs about 1/3 of the 070.
And we went with the Stihls over the Shindawas & Echos bescause they used the same mix as the lawnmower & weedeater.
When you do decide, fit the smallest recommended bar for the saw.
A big motor pulling a short chain on a small bar will make shorter work of any job than a small engine dragging a long chain around a big bar.
And then also get 3 extra chains because when the chains are worn out so will be the sprocket.
