.105 line, and speed feed heads on a Chainsaw?????
Must be that titanium line I've been hearing about...:wink:
a saw was probably purchased already, but as a homeowner with clean up and cutting occasional trees, I got a Dewalt cordless with a 6ah battery. it's perfect. I can cut a full 6.5 truck bed of oak on a single charge. No gas to mix or keep, no fumes, I can talk while I cut. It's quiet when I'm not. I had an older stihl and it seemed I spend 20 minutes getting it running the couple times a year I'd use it. No I just drop the battery in and go. If I was cutting wood all day it would probably be a different story, but if I run out of juice, I plop it on a charger and go do something else. But like I said, by myself, 1 load of wood is plenty. it only ever gets burned for campfires so it lasts a while
