smhardesty
- Dec 8, 2022
- Threads
- 25
- 272
I had another mower come in with a brand name I had never heard of. It is a Pulsar model # PTG12205, with a serial number of PTG1220520090337. The engine data stamped on the back of the case is DV0150 19123092329. I have searched and searched and can't find a single site that has any parts for this thing. I'm not 100% sure, but this thing can't be over 3 or 4 years old, and might even be newer, at least by looking it over. The original, paper, stick on price tag is still on the top of the motor. I'd think that would have been long gone if the mower was older than a few, short years.
It might be an off the wall, cheap push mower, but it has a couple of features that are pretty nifty. First, the handle is shaped with the end turned up, giving taller guys like me a more comfortable handle height to use. Then, there is a really nifty height adjustment system. There is a nice, large handle sticking up on the right rear wheel you use to make the adjustments. The rear wheels are connected by an axle assembly and a rod runs from the left rear wheel to the left front wheel. Another axle assembly connects the two front wheels.
There is a slight problem with the front left wheel. The owner backed a big zero turn over the left front corner. It bent the left front wheel bracket and the rod of the axle assembly. I'm about 99% sure when I take the front end apart I'll be able to straighten things out, but in case I can't for some reason, I'd like to be able to order whatever new pieces I need. I'll also need either a carb rebuild kit or a new carb. I haven't tried tearing things down yet. Before I get armpit deep in this thing I'd like to know for sure that I can get replacement parts.
The only thing I found online is in the link below. You can buy a whole new mower, but they don't list parts. I have sent a message to them requesting info on where I can get parts, but haven't received any reply yet. Any help in locating a parts dealer will be greatly appreciated. Oh, yeah. I managed to find a site to download an Operator's Manual for it and that site also had a parts list diagram. When I downloaded the parts diagram it was so small I couldn't read it and when I tried zooming in things were so blurry I for sure couldn't read it. Heck, I even put my really strong reading glasses on and couldn't see things clearly. LOL!
https://pulsar-products.com/our-products/lawn-mowers/#
