dewguy1999
Re: Help: Lawn-Boy 21" SilverPro Series, 10247, DuraForce (2-cycle) behaving badly
I've read where drilling out the jets is a sometimes fix for surging, but I don't think I'm ready to try rebuilding the carb just yet, plus, I never had surging before last Wednesday. I'm hoping that it's the stale gas and when I get fresh it will behave itself. I don't know what the air induction tube is, is that part #95?578 that Lawn-Boy calls a "Tunnel E"?
dont waste your time with iso propyl or sea foam.It wont do anything.you need to remove the carb and clean the jets at which time you should drill out the jets with a micro drill bit set there are a few posts on this forum referring to the procedure.its worth the time to do it.you will see a great improvement in you mowers performance.your air induction tube is a necessary part as they would not have put it there if it was not needed.the induction tube works like a ram air scoop on a car scavenging forced air from the flywheel.if you take the carb off remove it as a unit not in two pieces as the govenor spring is hooked to the carb body.yes its a PIA but if you pay attention to detail its not that hard.
