Ethanol and Isoproply are two TOTALLY different chemical compounds. Over time Ethanol can contribute to problems in a 2 stroke, and pure Ethyl Alcohol (yellow Bottle of Heet) can cause gumming quickly.
ISOPROPYL alcohol simply combines with water, then mixes with gas and burns it up in combustion. No harm, no foul to a 2 stroke.
Adding small amounts of Red HEET (Isopropyl) to your 2 stroke will cause no issues. All it will do is help clean and take out moisture. Same with Seafoam. In small quantities it is safe. It's not just alcohol to combine with water, it's a fuel system cleaner. So no, Ethanol via your pump will not molecularly do the same thing as Heet or Seafoam. Ethanol tends to gum up a 2 stroke over time, Isoproply does not. Also, there are no CLEANING compounds added to Ethanol in gas. Seafoam and Heet RED bottle have carb and injector cleaners.
All this being said, we are all just giving you suggestions based on what we see and hear and read. The mower is missing and therefore surging. I believe the surging is being caused by the hit and miss cycle. This new behavior is AFTER your tune-up and adding a shutoff valve. Anything is possible. A small piece of something may have dislodged when you cut in the valve or a tiny piece of the valve may have got into the fuel flow and is now partially clogging a jet. There may be an issue with float, or needle, or jet adjustment. There may be an issue with spark. The new CDI may be fine at lower RPM but bad at high RPM. There may be an issue with a crank seal, or a reed, however, with no backfire, I am inclined to rule this out. There may be an issue with the spark plug. The exhaust port, or reed valves.
You have to go back to my previous post. These are what I would do in order;
First: FRESH FUEL!
Second: NEW SPARK PLUG. For a few bucks, replace it if it is not new.
Third: MAGNETO AND FLYWHEEL. Is there RUST on the flywheel magnets? Sand it off. May not be your problem but if it started when you put the new CDI on, then this is highly suspect! Put on that old CDI and try it.
Forth: CARB ISSUE. Bad adjustment or poor venturi flow through a jet, bad float or needle valve.
IF it ends up being a Carb issue, I thought I'd give you a quick way to try and clean the carb without total disassembly. The Seafoam trick sometimes works in the gas, and if not, usually works if you soak the carb in seafoam overnight.
WE are going to hope that it is not a Reed Valve (easy to check when the carb is off) or a crank seal problem. And we assume your Governor is working easily and freely and that the wind vane is traveling well.
I found this vid on Youtube for your mower on carb cleaning to fix hunting and surging issues. Not specifically your "missing" issue but a nice tutorial for taking off and cleaning the carb on a Duraforce, including bowl removal and float check.
https://www.youtube.com/watch?v=n5sYTvYQpI8
