305
- Mar 2, 2021
- Threads
- 4
- 28
That makes perfect sense. I will disconnect the ground after use over the next few days and see what happens.
I was thinking it was not charging at first because the head lights would get bright or dim depending on the engine rpm. Then I realized that is how it works with this type of charging system. I had a mini-bike me and my father built when I was a kid and it had a briggs and the head light would do the exact same thing especially when the magneto gap was not right.
Thank you for the help. I will report back Monday and let you know what I found.
