Change in wire color means that it is spliced somewhere, as it goes to three safety switches involved.
Thanks, Riv.
But sheesh, I spent hours tonight on this, mosquito bitten, back ache, and so far, heres what I got:
1) Solenoid is still good as it clicks when jumper wire goes from pos to small terminal (right?)
2) I tested ohms on BOTH safety switches (cracked the tab on the hard to reach one) , and I got 0.4-0.5 Ohms on both. I got this value by touchiing one meter lead to one connector, and the other meter lead to one other. the other 2 tabs showed no resistivity reading at all (why?). Reading was obtained with the plastic "pin" depressed, of course. Are theese then good safety switches?
3) They say its rare for a ign switch to be bad. Continuity from orange wire on S terminal on ign switch to small term on solenoid showed no ohms. Again, color does not match, and we know the solenoid wire goes to the safety switch not the ign switch. So, not sure if this test is any worth.
