1 - a random plate screwed in on the outside of the brake lever guide says: "915 006B Peerless". It then also says "1248 000062" so that must be a late addition ID labelling since the casing has nothing on it but Tecumseh label and address and also patent numbers.
2 - the transaxle is belt fed from the engine from what I can see.
3 - I can clean it all with some 50/50 Purple power and water and then hose it all down if you think that will do the job without hurting the belts? Battery removed prior of course.
purple power is great for cleaning .. it removes paint on certain objects too !! Dan ... it does appear to get this brake working , it will probably
be best to drop the trans, looking at that photo from some manual you posted ..those pins sticking out of the housing on each side of the stud should be what pushes the pads against the disc..be sure to use your camera..looking at the diagrams in the manual can you tell which model you have ... the numbers point to a 900 series ???
Yep, Im sure I have the 915 series. Although my brake caliper is not removable which throws me off a bit from what the manual is saying. It must just be a mild (annoying) variation of that transaxle.
Agreed on the trans dropping and opening. I didnt envision being that intensive with the mower right away but I guess I have to learn some day. And the grass isnt growing too fast in Indiana this time of year. Time to enlist the help of a friend w the belt uncoupling and trans opening I think.
Thanks for the help guys! Much appreciated.
Looks like 915 it is. Thanks for a nice link to all them transmissions Boobala.
Dan, looking at and judging the last two pictures you've posted I'm convinced that there is nothing wrong with the rotor. Also, the amount of 'pin' that is sticking out tells me that there is a lot of meat left in them pads. If you could blast it all clean, get them two pins to move again you could be looking at perfectly fine working break that will last you another 10 years? What are we looking at? An hour of labor, maybe? But if you decide to get that tranny out and rebuild breaks 'the proper way'...then...8-10 hours of labor to get to $10 item? Think about it.
Very good point. I'll get the heat gun out and try to pull those pins today.
