A two frozen steel pins in aluminum housing...never easy. These pins need to move freely. Don't be afraid to put some heat to it and pull them out with a vise-grip. Those two 1/4" bolts holding the break assembly to transmission housing...real easy to break them off if you're not careful. Not pretty! If you do, you're looking at drilling out what's left of it in the hole and re-tapping.
I've got two mowers with exact same transmissions as yours. Did break jobs on both of them long ago and don't recall how exactly rotor is held down. Remember that it wasn't a big deal at all. I think it was a single Allen bolt right in the center holding it down to the shaft. Biggest problem (as I recall) was taking them two bolts holding the front bracket out. Let me take a look at some diagrams and I'll get back to you with details.
Yeah. They call it a cap screw (#4 on diagram) that is in the middle of the (#8) break disk that goes onto a shaft that goes thru a seal, a needle bearing, a washer, spur gear and that is it! Easy does it. :thumbsup:
That's NOT 800 series trans!!! That thing doesn't come apart like I told you. Looks like you gonna have to drop the tranny and split it in half to get to it. Look at it from this angle...still not a big deal and you get the opportunity to clean the old grease out and lube it all nice and fresh on the inside!!!
Thanks Jack and Boobala. That's what I was fearing. Not a big deal though, like you say, in the long run I'll be more knowledgeable with my mower and hopefully prevent future issues.
Any recommendations for transaxle lube and sealing (silicone instead of gaskets?) to save paying the John Deere premiums?
This Peerless manual may be helpful in some way .... I'm hoping ...Boobala
http://www.barrettsmallengine.com/manual/tecumsehpeerlessmanual.pdf
Boobala...help me out here! What is he got? 600 series shows exactly what I told him to do before? But 700 is just the other way around. I bet that he's got the 700!!! Never easy!
It appears to me the brake is NOT part of the driven axles.. it is on a gear carrying shaft ( same idea ) however , it appears the disc is splined and may be removable without splitting
the trans .. too much dirt in the way...... a superior cleaning is in order to get better visuals.. also I did NOT know this is a Rear Engine Rider
I have never worked on a RER .. so I don't know how the trans couples to the engine , hope its just belt ..
all we can do is wait on speedydan ....he has a manual ... Im hoping I sent the right one . Will surely be much easier with trans removed !
1 - a random plate screwed in on the outside of the brake lever guide says: "915 006B Peerless". It then also says "1248 000062" so that must be a late addition ID labelling since the casing has nothing on it but Tecumseh label and address and also patent numbers.
2 - the transaxle is belt fed from the engine from what I can see.
3 - I can clean it all with some 50/50 Purple power and water and then hose it all down if you think that will do the job without hurting the belts? Battery removed prior of course.
purple power is great for cleaning .. it removes paint on certain objects too !! Dan ... it does appear to get this brake working , it will probably
be best to drop the trans, looking at that photo from some manual you posted ..those pins sticking out of the housing on each side of the stud should be what pushes the pads against the disc..be sure to use your camera..looking at the diagrams in the manual can you tell which model you have ... the numbers point to a 900 series ???
Yep, Im sure I have the 915 series. Although my brake caliper is not removable which throws me off a bit from what the manual is saying. It must just be a mild (annoying) variation of that transaxle.
Agreed on the trans dropping and opening. I didnt envision being that intensive with the mower right away but I guess I have to learn some day. And the grass isnt growing too fast in Indiana this time of year. Time to enlist the help of a friend w the belt uncoupling and trans opening I think.
Thanks for the help guys! Much appreciated.
Looks like 915 it is. Thanks for a nice link to all them transmissions Boobala.
Dan, looking at and judging the last two pictures you've posted I'm convinced that there is nothing wrong with the rotor. Also, the amount of 'pin' that is sticking out tells me that there is a lot of meat left in them pads. If you could blast it all clean, get them two pins to move again you could be looking at perfectly fine working break that will last you another 10 years? What are we looking at? An hour of labor, maybe? But if you decide to get that tranny out and rebuild breaks 'the proper way'...then...8-10 hours of labor to get to $10 item? Think about it.
Very good point. I'll get the heat gun out and try to pull those pins today.
I was reading through the Peerless Manual I sent... it seems the brake could be mounted on either side but no mention of splitting cases for brake repair. Like you thought.. you must have some variation of a 915 trans. The diagrams in the Peerless manual appears that
all those similar models 700 thru 900 series all have a typical removable lower brake housing ..View attachment 31337
But your pic ... doesn't seem to represent that !!! ....View attachment 31338
SO ... it's beginning to seem .. like the trans may have to be dropped if you can't get the pins out ... but you may only be able to replace the pins and MAYBE the outer brake pad plate and pad ... PATIENCE ... keep working on the pins ... actually , ..I believe the only important function of these trans brakes is to stop trans moving gears to allow shifting of gears ... pulling the engine throttle back usually slows the tractor itself ... granted the brake is there for helping in that issue . As usual keep us up-dated ..Boobala
