CrusinSusan
- Oct 19, 2020
- 44
Just noticed you said it would be fine off, oops. Ty!Is there any harm in leaving it off? Everything seems to run perfect with it off. If it would damage it I’ll just keep fiddling. Ty again
I was racking my brain last night cause this aerator engine has always started up every season, first second pull no problem. Ran great, always check/change oil and grease bearings on schedule. The only thing I can think of I did different was instead of running it dry of gas like I have been I remembered I watched a video saying that was bad for the gaskets blah blah and to pour some stabil 360 in with a bit of gas and leave that for storage . I should of left good enough alone, lesson learned lol. Could this be a carb issue you think? Even though it starts right up and runs? (Granted it don’t run correct and has high rpm’s now) or maybe a governor issue? Would valves being off cause that? Very much enjoy learning from you guys and I appreciate it as always!No problems what so ever
All that happens is you can get a little fluttering when the governor allows the throttle to open up .
