Shughes717
- Jun 12, 2014
- 4
- 1,230
Good to know, thanks Ric. Do you know the diffs btw these and the 3400's?
I understand ric's point about the larger hydros, but I don't entirely agree that there is no benefit with the larger hydros. First, these commercial mowers can mow well up to 10 mph if the grass is mowed regularly. I mow mine at full speed and get a great cut, however, if I go any longer than 7 days between mowing I have to slow down. If the mower has zt3100 hydros or smaller then the top speed is about 7.5 to 8 mph. Two mph faster helps get large jobs done quicker. That is why I can mow my lawn much faster with a 48" deck mower than the previous owner could with his jd mower and a larger deck.
The second thing that may or may not apply to what you want from a mower is the ability to tow things, such as pull behind sprayers, or trailers. The larger hydros increase the tow capacity of the machine. Larger hydros usually come on mowers with wider tires, and are heavier. Mowers with larger hydros handle hills much better than mowers with smaller hydros as well.
The last thing I will point out is, although Ric brought up the point that he got 1400 hours on a mower with smaller hydros, heavy duty hydros are designed for more rugged applications and should last longer. Ask yourself this question (if I had to choose between two mowers of the same price, with the only difference being one having the smaller zt3100 hydros and the other having commercial zt3400 hydros, which one would I choose?). I know which I would choose. You can ask yourself the same question concerning engines.
I will agree with Ric that kohler is a good engine. I had good luck with the ones I have owned. The Kawi engine on my current mower just happens to be the best engine I have ever had on a mower. If someone is only mowing an acre that is flat and doesn't plan on pulling anything then Ric is absolutely right, you won't get much benefit from the larger hydros. If you have several acres and/or plan on doing more than mowing with the machine then the larger hydros would be worth the extra money.
