I used the Cub today for first time after a few weeks. Had the battery out during the arctic blast we had just before Christmas. Charged it and tested it, it showed good with 215cca against 230cca spec. When starting the tractor, frequently there is a delay when first turning the key, then the motor will turn over and fire. Is this the starter about to go out? I know my connections are clean and tight.
Another concern is the tractor does not want to backup especially when cold. And it seems to be worse when it hasn't been used in a long time. I blow off the tractor every time I use it so don't think its an issue with grass clippings blocking a linkage.
Any advice? The machine is still under the 3 yr factory warranty for about another month.
