- Nov 29, 2014
- Threads
- 64
- 24,745
Look at the wiring diagram.
The S terminal on the starter gets is power via the key switch from terminal S2 on the key switch ( they are generally numbered )
S2 is powered from S1
S1 is powered from the brake switch
The brake switch gets it's power from the PTO switch and the PTO switch gets it's power from the Key switch via the fuse.
The most likely cause is a wire that is broken just at the terminal.
I trouble shoot by bypassing each of the switches, one at a time by pulling the plug and jumping across the plug with short wires fitted with a spade at each end.
It is a slow process but eventually the culprit will reveal itself
