PTO switch. When the key is in the start position, I have 12v going into it, but nothing coming out. Could this just be a faulty switch or something not grounded?
Starter solenoid tested good.
Wilbur?Folks who's electrical skills that are somewhat lacking and tend to butcher wires for no apparent reason i refer to as a "Wilbur"
Either way, it's a pure headache. I had to fix about 5 other wires that he'd cut and reconnected. His connections were crap.
what's your preferred splice method?Yeah, seems like 99.9% of people thinks twisting wires together and some tape is a permenant fix.
I usually twist the wires together,solder them and then heatshrink tube.I don't know about Hammer's. But I like to take the metal connections out of the inside of the plastic covers they come in, crimp them to the wires. Then use the shrink tubes. I use enough to have at least 1" to 1.5" on both sides of the connection. It's sort of pain in the rear getting the connections out of that hard plastic. But I can see see exactly where and how it's crimped. Plus I can tell better how much wire I have inside the crimp.
What's yours?
