- May 6, 2010
- 12,013
Because you throw away the locking collar and use the bearing. The bearing has a flange on the side that the locking collar uses to secure the bearings, but without the locking collar some companies use the flange as a bearing spacer. Some Dixon spindles use the same bearing.The ones that came off this deck didn't have the set screw n them. And none of it was black.
