Govoner linkage question- m:31d777
Kartrcr02
Code:
i have a troy bilt riding mower and was wondering how to hook the throttle and gov linkage back up.
M-31d777
T- 0233e1
C- 030326zd
pugaltitude
SeniorCitizen
I can't help you with this one but I can suggest a way to prevent the problem in the future.
Before disconnecting anything , springs , linkages etc., using a paint touch up brush or similar , color code each connection . EXAMPLE : If you touch a spring end where it connects in a linkage hole you're done with that end . If the spring has dis-similar ends, use a different color on the second end. It makes assembly easy the next day or 3 years later.
