Governor issues after changing sump
Gary House
Briggs twin cylinder OHV.
You said in a previous post that no gasket was used just sealant.
You can go to this link and see a gasket set for your engine and the sump gasket #12.
You say you bought it NEW.
Appears Wilbur may have been into the engine and did not use a gasket.
I do not know about those popping sounds you heard unless the engine maybe blowed a head gasket and pressurized the sump and blowed out the sealant?????????? When you get governor control you may still have popping noises?????
Those cracks in the sump may be casting flaws???????????
Now for the governor itself..
Do you have the Briggs Intek twin cylinder OHV SERVICE manual?
If you have done the above static gov adjust and the governor is still not operating do the static governor adjustment AGAIN and tighten the clamp nut on the governor arm to specs. I've seen those governor shafts coming out of the engine slip (rotate) on the arm if you just use a nut driver and/or a weak wrist.
Be careful and tighten the clamp nut to specs but do not break the clamp. That Governor shaft coming out of the motor only moves about 45 degrees or little over 1/8 inch rotation on those engine for full governor control on the LONG carb governor lever. You can test the full rotation of the shaft CW and CCW with the 1/4 inch nut driver on the end of the shaft with the engine NOT RUNNING. If the arm slips due to not being clamped good the engine will run wide open. Also make sure the governor spring is connected properly.
I've seen first hand what you describe when the governor arm and or sump has been removed and re-installed due to the arm slipping on the shaft. On some Briggs engines I had to remove the governor arm bolt and turn it around opposite direction so as the lock nut was more easily accessible using straight extensions.
I've even adjusted the Static governor adjustment backwards (so as the governor would hold the engine at idle when started) to make sure the governor shaft is rotating or attempting to pull the throttle towards idle.
When starting the engine after adjusting the gov hold the carb throttle shaft manually at idle start the engine and then slowly let the gov take control.
You can manually keep the engine from over speeding and ruining itself until you get/see correct gov control.
Let us know what you see/find?????????
Thanks. I appreciate all your suggestions. I'm going to attempt to start the engine in a little while. I had to charge the battery because the mower hasn't been started in several months.
Gary House
Reference IPL.
The sump was change July 16, 2015. The OPs engine was made July 18, 2016. So first did the OP order the correct sump (594974)? If so then no gasket other RTV was used.
Now the earlier sump did use the 0.015 Gasket and new screws.
As for the old sump I see both castings and cracking.
I did make sure I ordered the correct sump. I searched for a gasket set on Jack's small engines but with the date code on my engine it did not show a gasket so I used a high temp silicone sealer.
Gary House
Ok. I figured out my problem. I failed to see the rod coming from the throttle on the carb. I hooked it up and now it works as it is supposed to. You'll have to excuse me, I'm old. Thanks for all your help. I'm sorry if I wasted your time.
Well if you learned and we all learned something from your mistake then it was a complete waste of time. At least you was willing the admit you slipped up and let us know the final solution.
Sometimes we don't see the trees for forest. We all at one time or the other been there ourselves. I one time got distracted and forget to tighten a oil drain bolt to spec. We lost a Mack 18 wheeler engine because the plug came out and the driver couldn't the big red light on the dash until the engine stopped. Dang cell phone was part of the problem.
shadetree#1
Thanks for the comeback.
I need to start paying more attention to the engine code when looking at IPL's for Briggs engines.
