Going nuts can't figure out why blades won't engage!!
floridaguy202000
So a few days ago i was mowing and turned off craftsman mower model number 917.259550 because i noticed a lot of old grass under deck. So i got back on started mowing turned Blades on starting cutting grass then heard a pop. I have the gas tank off but it seems this craftsman don't have a blade engagement cable? I have looked under the deck and see no place to put any springs. And the blade level is very hard to push up now.
Did the belt break ?
I would take the deck off then try to move the lever if it moved easy then you need to look at the deck. Make sure the idler pulley moves as it should
Google the model number and you can pull up a pic of the deck.
Looks like it just puts tension on the engage lever.
Move the deck parts by hand to tighten the belt, so you see how it works, it will be clear then.
