Carscw
Here's a funny...I have a 17 year old homelite weedeater I bought for $69. When we moved in the house all the plantings were new so I didn't want to wack the heck out of them. I screwed the idle adjust screw in till it was above idle just a bit and have used it that way ever since. Hardly evrr touch the throttle. My "theory" on the cheap homelite was I'd throw it away when a spark plug didn't fix it. Its still running perfect. I don't think there is a fan on it like a 4 stroke engine. I see the theory that the fan on the four stroke runs faster at full throttle....but all the moving parts are going faster too. Maybe I'm screwing up but I've never burned an engine up yet! I'll play with the thermometer some....but w/so little lawn its gonna be hard to run a comparison.
My wife never runs the trimmer full throttle.
One more thing on not running your mower full throttle.
You are running gator blades. The faster they spin the better job they do. They do have a minimum blade tip speed requirement.
I will put it this way. If you can hear the hydros whine then you need to bump the throttle up.
If you are happy with running 3/4 throttle then keep doing it.
I was not trying to criticize you. Was just saying what the manufacturers suggest.
