- Nov 29, 2014
- 65
- 24,995
I just purchased a steering bracket assy. including the mounting bracket,fan gear, and all attaching bolts and bushings for the gear.
When I get that I will have the setup test bed that I have been wanting.
I'll be able to test methods and modifications to tighten up that assembly without
incurring down time for the tractor, which I still use regularly for leaf-mulching duty.
After tightening up the fan gear mounting and pinion gear meshing, I'm thinking
spherical washers for the upper drag link attachments and Heim joints at the spindles.
You need to get rid of those pin type tie rod ends as well.
Get the spherical ball ones but pay the extra for steel and not the zinc cause the zinc ones will break.
Buy some longer mounting bolts in grade 8 or better so that the tie rod end is on the solid shaft and not the thread
Now if you want to be real annal weld some tube on the fan gear over the pivot hole then bore the tube and hole out to take a double row ball or roller bearing and naturally a longer pivot bolt.
This will not only reduce friction & wear on the fan gear pivot hole but substantially reduce the effort required to turn it
