- May 6, 2010
- 12,035
If that new meter will test frequency put it on that setting and insert the leads into the outlet. if getting around 30 hertz instead of 60 you most likely found the issue.Star got ahold of a MM that measures capacitance... 27.52uf so it's good.
I asked neighbor more questions and he said the engine ran "rough" and he and electrician could only test generator with 1/2 throttle???
I'm gonna pick up on ILENGINE suggestion and go to engine side. Neighbor said the gas has plenty of Stabil in gas and I suspect that "plenty" may be the issue.
Gonna drain gas and put some of my own in a see what happens.
The generator was stored in cellar and always drained the tank and had regular maintenance. It literally looks like it just came out of the box.
