- Sep 24, 2017
- 286
- 6,864
Occasionally it can be some trash in the fuel that gets stuck between the needle and seat.... usually the rubber gets old/wore, gasoline and rubber do not seem to mix.... More so the ETHANOL in the gas.
I've never heard a positive anything from anyone using waste-of-money-foam. It will not help you. Only lighten your wallet up a bit.This model is a push mower, 20". Does not seem to have a fuel filter, definitely no fuel cutoff. It does seem to use quite a bit of oil. I wonder if I can clean the carb using SeaFoam, and see if that helps the needles.
Might want to get that fuel leak repaired asap. Don't risk burning down your mower, shed and house.I used SeaFoam on my RV Generator and it did a great job. Took it from barely running and stalling out to running nice and smooth.
Right now it seems to leak gas out the filter area mostly some time after it has been shut off (like when I put it back in the shed). If that help diagnose.
sure sounds like the needle/seat is leaking some... eventually it can fail all together and fill your crankcase up with fuel.. Not good if you dont notice it..I used SeaFoam on my RV Generator and it did a great job. Took it from barely running and stalling out to running nice and smooth.
