Well still have problem once in a while. After shutting down and let it sit, will hydrolock with a cup of gas coming out of spark plug hole once I pull plug. Am confused. Some how think fuel getting to engine thru pulse line. Have already gone thru carb even tried new carb.What was the fix action? Dirty carb?
Thank you, will pressure test needle and seatThe Fuel Pump Impulse hose will fill the crankcase not the cylinder when the diaphragm is leaking.
Needle seat could still be leaking. Just did a Kohler CV with a carb with none replaceable seat, it gave me fits because had micro imperfection. It took 3 tries with the counter sink to get it to hold 10 psi for 30 minutes.
The first time I did a quick check and it passed but a few days later while loading the mower for the customer the engine started flooding. So that why I go lick my calf over a couple more times at the bench before I felt it would hold.
Your old and new carbs should of been pressure tested. New parts don't mean new these days.Thank you, will pressure test needle and seat
And you can install a manual fuel shut off valve between tank and the fuel pump. This is probably the cheapest most reliable method of controlling this problem.We have had a recurring issue with a Scag 48 with a Kawasaki fs548v engine. Twice it has started to run rough and died. Gas was 3 or 4 inches up in the dipstick and fuel was leaking out of the muffler. Took carb apart and cleaned thinking needle was stuck. Did an oil change and it was fine for a week but has happened again. Compression is even on both cylinders it is only 70 psi but manual says minimum is 65 psi. Leaning on a new aftermarket carb. Was thinking possibly fuel pump. Is there a way to test with a vacuum pump?
