Gas in my Oil Carb replacement for Generac 060242 power washer
welchs101
  • / Gas in my Oil Carb replacement for Generac 060242 power washer
I have a Generac Model= 060242 Power Washer and it had carb issues. I cleaned the carb and it actually helped out a lot it did not need to be chocked to run. However, after changing the oil and then the next morning i noticed that the oil smelled like gas. I think i found the problem with the needle but i am not sure.
My question right now is what carb replacement or repair kit would work with my carb. Not sure where to find replacments.
Note: i am not an engine guru.........i am learning about small engines so please do not assume i know what i am talking about.
i have pics of my carb if that woudl help..........there has to be something on the carb that would identify it right?
0K10430120 is the part number for the carb you need. That is the number that you look for and order. Listed both Jack's small engine and Partstree for possible locations to order from.
welchs101
Thanks. I see the part number "0K10430120" so thanks!!!!!!!!!!!
But how does one know "what company made the carburetor"? is there a way to find out?
Scrubcadet10
Moderator
Staff member
A.K.A, "SuperCarb"
Looks like SP made it, stamped on the side of the carb,
sgkent
here is the problem. The manufacture buys a carb they can trust. It works many years for the owner. Then it goes bad and the owner isn't comfortable rebuilding it. So the owner asks, "where can I get this carb?" The answer is given, but the owner sees a price that seems like a lot. Then someone says why not buy a Chinese copy for a lot less. Now we are in a crap shoot, maybe it will fit, maybe it will work, or maybe it will be someone else's return to Amazon when it didn't fit or work on their engine. Buy the right part. The manufacturer will not sell one directly to you for less than you can find it at a place like Jacks. You may find a new old stock one in an original box on fleabay for less but don't get a clone. Do not get caught in that trap. Or pay a local shop to rebuild and test yours.
words like "fits models," "replaces," "replacement carburetor," "for models," or "same as..." typically mean it is a clone and not the original part the factory chose.
And to add to the above , none of those descriptors say it actually works they all say it will fit in the same place and connect to everything without alteration .
The good carb factories test every one as it comes off the line.
Tests good and it goes to the purchaser
Tests bad and it gets sold as "defective"
Small factorys and workshops buy the defective ones, pull them apart & make a repair after which they get sold into the aftermarket parts stream
Whet they can't fix get bought by a lower lever repairer who will fix things like casting with holes or holes that have broken through the casting etc etc etc and then tey get resold into the aftermarket parts stream
What they can not fix gets bough by et others & thus the cycle repeats till there is nothing left but absolute unrepairable junk which gets sold as scrap metal to factorys who pull them apart so the different materials can go into the materials stream as quality scrap .
However a lot of this stuff, seems to end up back in the parts stream again .
A maker of quality parts puts their name or the customers name on the goods and top quality ones will also have a serial or date or batch code
Junk makes put nothing on the product so it can be sold by lots of different people pretending that they made it or it was their design or because it is total junk so they don't want to be identified ( or sued )
The take away is
Unbranded , in branded packaging = lowest quality that is acceptable
Unbranded in unbranded packaging = junk
welchs101
I hear what your both saying. My interest in the "manufacturer" is that i thought generac might be adding on to the price and if i could find out who makes the carb maybe i could get it from them or find a replacement made by same manufacturer. Sounds like this approach is not a good one ............i get / hear what your saying.
One last question: One last question and if you want me to start a new thread i certainly can and will. The reason i was looking for a replacement carb is i had gas in my oil..............
I opened up the carb and cleaned it.....................i looked closely at the needle and seat. I cleaned it really well. I "think" it is making a good seal..........i say i think because ...after cleaning the carb i drained all the oil out of the motor. filled the gas tank up and was waiting to see if any more gas went into the crank case by checking the oil drain location for gas. I did this for several days coming back to chk to see if any gas would drain out of the oil drain. and for several days i did not see any.........then the other day i noticed a few drops of gas in the oil drain.................so this is why i was thinking of replacing carb..........any gas at all is not good right? also, any idea where to find just the needle for this carb?
sgkent
you might be able to take it to a local shop and see if they can match the parts to a rebuild kit. The parts fiche does not show a rebuild kit for that carb that I could find online.
