Fish
- Aug 2, 2013
- Threads
- 11
- 5,130
Try loosening the cap when it starts to die.
Also, is the tank higher than the carb? If you disconnect the fuel line at the pump, does the fuel flow? If so, drain it into a can and watch things flow.
Is the tank clean, and the screen clear?
