c5vettster
- Nov 9, 2014
- 7
- 48
Or install a fuel shutoff valve.
I am curious as to how an engine with a fuel pump gets a crankcase full of gas overnight. Usually that's a gravity-feed system problem.
I have a fuel shut off valve and I have been using it since the "incident" and there were no recurrences. The gasoline flows freely through the pump when the engine isn't running. This is a standard pressure driven pump. Do you think I need to replace it?
