fuel leak
davbell22602
yes, i'am seriously considering replacing the carb. no adjust. on this carb.
If theres no adjustment on the carb then those are chokeless type that are not rebuildable. If it were me I find out to see if Echo used different model carb that has the H, L, and Idle screws on it. I have 2 FS46 that have the chokeless carb and replacing both with different model carb after trying to rebuild one with no luck.
briggs
hit it with a hammer or replace the carb
pete g
I,ve seriously considered that, also. I didn't know this carb was not rebuildable. its a RB-K75. if that's the case I will definetly replaced the carb and then hit it with a hammer!!!
briggs
Its makes u feel better ..Sometimes I do it after I replace the broken part so someone doesn't grab it and put it another machine...LOL :thumbsup:
pete g
I know I;ve done exactly that more than once. if these carbs can't be rebuilt why are there lots of rebuild kits on the market?
briggs
I thought of something that might answer my own question. you can buy I rebuild kit for my carb. problem is, there is no way to replace the valve seat.
is there not a screw that holds the little pin for the needle valve ...Post a pic man
briggs
LOL!! That actually makes sense...
yup i was throwing bad floats away and the young lad would go pic them up and put them in stock again ...So now i take make hammer and flatten it lol...Do it with carbs to lol ...Good stress relief
