That is yet another advantage of the Scag mower. If you were in the bind with a mower that the bolt was threaded in from the bottom you would replace a spindle. ON the Scag you can cut the bolt into on the nut side which is on top of the deck. We have done it and be running again in 15 to 20 minutes. We haul a 4 1/2" side grinder on the truck with a this cutter blade on it and have a small generator and also carry an extra blade bolt and nut. Scag mowers have so many advantages over their competition.
Thanks again everyone. Have not had a chance to work on it again. I do appreciate all the comments though.
