It is not a problem if you regularly remove the blades to sharpen them nor is it a problem with mowers that have a square, diamond, toothed blade holes or multiple bolts
On blades with plain round holes the the load on the blade resists the spindle rotation so the blade bolt tightens up in use.
More so if you rough mow, hit a lot of branches , roots or rocks.
One of my commercial customers has a council contract to mow the road verges in a semi rural area.
He mows over whatever is there, building waste, car parts , road kill, household garbage and his blades regularly need to be cut off.
OTOH the mower he uses for house yards is never a problem.
