Been spending the last few days working on neighbor (JRs) plumbing (for those who don't know, JR is 85). He has a spring fed cystern and Jet Pump at the house. Everything was plugged and he still has Galvanized pipe and a Galvanized pressure tank - I think we will end up replacing everything. It is a small crawl space and it has been in the 90s with high humidity. :thumbdown:
I check in to see what is going on, but haven't spent much time on the computer recently.
I don't envy you one bit...nice of you to help JR and I have replumbed two houses that had all galvanized. It's strong, lasts forever, but is a HUGE PIB to work on. I had some parts of it that were 55 years old and still didn't leak. And you could bang on them with a sledge and they still didn't leak. Try that with copper or plastic....:laughing::laughing:
Weren't leaking, but most were so full of rust and crud that a 1" pipe had about a soda straw size flow of water. The Goulds Pump runs, but won't build any pressure, so I guess the next step is to basically pull everything out and start over.
If you can get both ends open you could try blowing compressed air through the pipe to clean it out. I don't know how much rust you have but maybe the pipes don't need to be replaced.
