Been spending the last few days working on neighbor (JRs) plumbing (for those who don't know, JR is 85). He has a spring fed cystern and Jet Pump at the house. Everything was plugged and he still has Galvanized pipe and a Galvanized pressure tank - I think we will end up replacing everything. It is a small crawl space and it has been in the 90s with high humidity. :thumbdown:
I check in to see what is going on, but haven't spent much time on the computer recently.
I don't envy you one bit...nice of you to help JR and I have replumbed two houses that had all galvanized. It's strong, lasts forever, but is a HUGE PIB to work on. I had some parts of it that were 55 years old and still didn't leak. And you could bang on them with a sledge and they still didn't leak. Try that with copper or plastic....:laughing::laughing:
Weren't leaking, but most were so full of rust and crud that a 1" pipe had about a soda straw size flow of water. The Goulds Pump runs, but won't build any pressure, so I guess the next step is to basically pull everything out and start over.
If you can get both ends open you could try blowing compressed air through the pipe to clean it out. I don't know how much rust you have but maybe the pipes don't need to be replaced.
Good for you BK to help your neighbor! Twall I'd sure like to see that Rolex.Even more I'd sure like to have one.I've always said before I croak I'd like to own one....russ
Good idea there, but take it from me, the deposits that build up harden over time and there is no way any type of air pressure will dislodge the crud. You would basically have to use a sewer snake on a drill to loosen the stuff and unless you got it all out, then rinsed the pipe with a pressure washer, you would end up with the crud in all of your fixtures like faucets, etc. And as far as replacing existing galvanized pope with new, well, if you think copper pipe and fittings are expensive, you would FAINT when you saw what new galvanized costs. And because it's all imported now, I doubt if the quality is as good as the old stuff. One of the reasons old galvanized pipe is so strong and leak free is because of the extra thickness and sealing the deposits give....:laughing::laughing:
HEY BK, CONGRATULATIONS on getting to be a true, certified MOWER ADDICT and reaching 1,000 posts. I also noticed you didn't make any fanfare about it like I would have. Figures, nice guys like you who take the time to help others don't toot their own horn the way guys like me do....:laughing: :thumbsup:
X2Good for you BK to help your neighbor!
X2
With a lot of reasons to get discouraged these days......I would like to thank you for helping your neighbor. This to me is a bright spot and I find it quite commendable. Makes we want to give you a hand, if I was closer I would.
Also remember not to overdo it in this heat, drink plenty of water, and wear a dust mask in that crawl space, some of that dust can be a real health hazard.
Is that tank a pressure tank or just a storage tank? Perhaps it would be easier to abandon most of the old system and replace with pvc and cpvc?
Just trying to help.
Hey everyone it's been awhile!
That's awesome BK! I could have used your help when we replumbed our basement two weeks ago, but then again we went the easy route :biggrin:.
Changed all of the galvanized over to PEX. We had so much rust coming out of our pipes making the tub red and having to use rust out every week. :thumbdown: We had put in an iron filter a few months ago and and it didn't help at all, then realized the water out of the softener was good, but it was the pipes causing all of the problems.
It was a long day, but it was the time to do it before we finished the basement, all of the pipes were easily accessible. Now our water is actually drinkable from the tap and our tub stays white!
Anyways, glad to see everyone again :thumbsup:
Old galvanized pipes will always discolor the water, copper rarely builds up deposits enough to discolor the water.
It had been a couple months since we had enough rain to make the rain gauge move any. Strange that the grass kept growing (not quite as fast, but more than you would think). Just a couple days ago, we got under 0.2" and 25 miles north they got over 7" in a couple hours. I don't want that much all at once, but it would be nice to get it over a few days :smile:. I'll settle for the 1 1/5" and more expected later in the week (if we can believe the weather people
Hope all the drama over language police is nearly over !
I was helping my brother and nephews with roofing all last week and was so tired upon getting home I didn't mow, and of course it rained all weekend....grrrrr.
About the "language police", what a stupid waste of time, making such a big frickin' deal about HTF I worded a thread. MORONS is too kind a word to describe them and their ilk. CRETINS may be a better term. I personally don't give a flying, flipping, BLEEP what words are posted on this or any other forum. I am a big boy, I have been called names that would make a sailor blush, a little cussing isn't going to make me avert my eyes and babble "Oh, you can't say that HERE" because it's not my place to censor LMF.
