Freshly Acquired Snapper V21 Aluminum Body
With my limited mechanical knowledge my only advice is this: since it was your grandfather's don't get rid of it. Keep it, running or not.
Re: Freshly Acquired Snapper V21 Aluminum Bod
I'll check it out on the eBay. Will any 3.5hp briggs work or only a 1972 for the magneto. I know carb has to be correct. The governor springs seem stretched as well. Will a carb kit come with those or seperate?
A couple more pictures....hope they come out, I'm uploading from my phone
Another question, Should I get it running and just mow and be done with it. Or should I get it running, then strip it down and repaint and restore it?
That's a toughy for me.
I've done a couple of complete tear downs and re-paints. I've come to realize I prefer original patina, however the condition, over re-painted. It just feels more original. Now that's a call u have to make for yourself but that's my opinion.
The 21500PC I refurbished last year looked really good when complete, and if I kept it in the garage for display only it may have been fine...just to look at. But I wanted to use it and I did and spray paint just doesn't hold up like the original finish. Powder coating is an option that would be better, but cost more too. If u decide to reprint I'd look for original decals to put back on. Clickitandstickit dot com is great for that. They'll make any decal u need, all the need is a picture and dimensions of the decal.
I was able to find the ignition coil on ebay. They vary in price from 15-29$....I cannot find a positive source on the carb kit. They seem tricky with the numbers and such.
Here it is with the flywheel cover off. There's 2 wires off the mag. One goes to ground the other goes under the flywheel. So it still has points? Should I pull the flywheel which is easy for me to do. Or just put a new electronic mag and eliminate the points.
I would eliminate the points.
New coil is ordered. In the mean time I will clean up under the the cover, clean out the carb. and it should be good to go.
Diaphram in the carb was completely shot. It was rusted and the piece for the choke was not connected to the diaphragm. I ordered a new one and should be here tomorrow. The coil should be here tomorrow or sat....i hope to be mowing by sunday
