FR691V Sudden Power Loss Overnight
Rondoman
Even worse problem than I thought. When the rocker arm support worked loose and let the pushrod go into orbit, the impact broke the lower end of the camshaft. I have a replacement camshaft but no place to do a partial disassembly to install it. If I can find such a place, I am guessing that both rocker arms with rods must be removed and the alignment marks on the driveshaft and camshaft matched. This is new territory, but I have had to do similar work on a car back when my hair was black and I had a lot more of it.
7394
Hang in there, you will get it sorted..
Check the head carefully
Usually when that happens the rocker mount shifts and takes out the locating pip in the head .
I now repair them by grinding the surface flat & fitting grub screw then peening the thread so if does no back out .
For the want os an extra 0,0001 oz of aluminium they could have made it a tab rather than a pip & his would not happen.
Rondoman
I have suspected that there is collateral damage such as deforming the rod supporting bowl on the rocker arm a bit. I also figured I would need to peen the threads on the bracket retaining screw. My problem is that there is no way I am going to be able to fix this without good lighting and a clean work table. All I have now is a muddy barn floor and winter coming on. I did have a pushrod destroy a piston head on another mower, definitely not a repair job for superglue and JB weld. LOL
Scrubcadet10
Moderator
Staff member
one of these works well, folds away taking up very little space. I have one.
