My Dixie Chopper ZEE 2 is 7 years old and has never given me even a hint of a problem; but after a sudden cold snap the other night, it began to have a power loss after about 15 minutes. I replaced the plugs (never thought that was the problem) and then both the fuel filter and the air filter. That did not help at all, so I replaced the fuel pump next with no improvement. I noticed though that the clear fuel filter has very little fuel in it as though the new pump is not working. I have found no line obstructions nor air leaks nor any evidence of rubber deterioration. Since I was desperate, I went ahead and ordered a new carb. There is no misfiring at all, just obvious loss of fuel to the engine. A relative said that it probably is the fuel sensor on the carb. Am I headed in the right direction or still just swatting at no-see-'ems and hoping I finally solve the problem?
