Flywheel Removal
LSU-Mike
Any tips as to how I should attempt to remove the flywheel from my Kawasaki FH580v? As you can see in the photo it is held on by bolt, not by nut and there are no holes to attach a wheel puller. I've watched several videos, but none seem to apply to this engine. I'm trying to access the breather cover/gasket in hopes of stopping an oil leak. I've applied a good dose of PB Blaster penetrating oil and realize it might take more and plenty of time.
Thanks
txmowman
There are two indentations casted into the side of the flywheel. To do it properly, you will use a two jaw puller. You could probably borrow one from auto zone or similar. Make sure you put a washer on top of the crankshaft to protect the bolt theads.
LSU-Mike
I'm off to see if one available to borrow from O'Reilly's has enough "wingspan" to reach around the 8+" flywheel and if the grab ends will fit into the indentations.
Thanks again txmowman.
LSU-Mike
I attached a two jaw puller as suggested. Several doses of PB Blaster. Tightened down and left over night. Doesn't appear to be moving at all. I tried heating the flywheel some with a heat gun. No help. Any other suggestions besides continuing to apply PB Blaster and waiting?
txmowman
Is the puller a beam style like pictured? Or more of a jaw type? A jaw puller my not exert enough force vertically.
Hammermechanicman
I remove those by installing a longer bolt that bottoms out in the crank threads then use a pry bar to bias up the flywheel and hit the bolt with the air hammer.
LSU-Mike
This is what I've tried. I'll seek another style.
LSU-Mike
Not sure what you mean by "pry bar to bias up.."
Hammermechanicman
You should have .004-.008 endplay of the crankshaft and the block. You place some kind of small pry bar or screwdriver between the block and flywheel and pry up just enough to bias the crank and flywheel up that few thousandths.
And using a puller at the time you smack the forcing screw once the puller is tighten up; re-tighten forcing screw after each blow. Preferably with a brass hammer and not with Hammermechanicman.
So far in 14+ years only had one flywheel that I could not remove.
