Flywheel Removal
LSU-Mike
I had tried a few smacks of the force screw as suggested by StarTech, so after his reenforcing suggestion, I tried a few more and it popped loose. Wow, what a mess underneath. Now to get it cleaned up and to see if I can find the breather cover and see if that's the main cause for this mess. I might be back for more help.
Thanks all
SeniorCitizen
I've seen so many mechanics heat in the wrong location so it also heats the shaft where it's stuck . Heat the outer most part of the flywheel and the heat there will draw the wheel from the shaft .
