First things first...............
You need to buy the land first. Then when you know if you have hilly ground, many obstacles to mow around etc. you can buy a mower to better suit your needs.
Wow I had no idea you were that close to me, you're probably less than an hour away from me!Depends on where in VA - if it is close to Culpeper or Charlottesville I could recommend some reliable dealers that would not soak you ! AND steer you away from some that would !
I can advise one place to steer clear of, James River Equipment in Ashland Virginia, they will burn you bad.
Random question: What the heck do you have that you need a Ventrac for? I'd kill for one of those things but for what they go for I think I'll buy a car first.
Thanks to everyone for their suggestions. I am presently looking for some land pretty close to Charlottesville. Between Charlottesville and Richmond actually, so I would welcome a recommendation of a dealer. I would go the John Deere route, but I'm working with a budget.
Well if you are referring to the cheap little things sold at the Big Box Stores I do not even regard those as true John Deere's."If you are on a budget then buy a John Deere cheaper in the long run"
That might be true, but only for the upper level machines. The "entry level" mowers seem no better than all the other brands, and yet you still have to pay - simply because it says Deere on it...![]()
