 - Sep 24, 2017
 - 286
 - 6,864
But my good buddy Billy Bob Brown told me John deere just opened a new oil filter making plant in Indonesia.......Briggs, kohler, Kawasaki, John Deere don't make oil filters.
It begins.
It begins.
And you got a fairly strait forward answer.Not sure where in my post I made it sound like I owned a space shuttle... I just asked a fairly straight forward question about a filter.
Technically, it can.I just wanted to change it before 20 hours to get the rest of any wear-in bits out of it. That means the filter too. I'll then do regularly scheduled changes.
I know I'm being overly cautious, but for $20, it can't hurt.
Quality parts are always branded
You are stressing over nothing.
It makes no difference which filter you fit.
They are all the same internally .
there is next to no difference internally
the only difference is physical size of the container because of space constraints once fitted to the mower.
However there are a lot of parts like filters that were consigned to the scrap bin then magically get returned to the parts supply usually through amazon or Evilpay because the vendors there have no liability for the rubbish they sell .
A lot of factories are fitting house branded Chinese made engines and these come with a filter with no branding apart from a sticker, which being a sticker can fall off.
Quality things like oil filters will always have a number painted / printed directly onto the body so if a faulty one is found the batch can be identified and recalled.
Buy parts from a mower shop or specalist on line parts vendor that has their own web page and you can sleep at night knowing that the parts you fitted have a warranty and should be of good qua
Dude, I'm not stressed. You're the one that shouted "It is a LAWNMOWER not the space shuttle."And you got a fairly strait forward answer.
Buy parts from a mower shop or specalist on line parts vendor that has their own web page and you can sleep at night knowing that the parts you fitted have a warranty and should be of good quality.
Which Wix filter ? Have usrd in the past and had severe leaking from around seal.I have the 708cc engine.Wix filters is all I use.
Ah, the Toro/Exmark branded Loncin engine. The WIX 51394 or NAPA 1394 filter that you have been buying will not work. The filter’s base bottoms out before the gasket is completely depressed. Save yourself some headaches. For the 708cc Loncin engine, use a FRAM 4967 series filter or a STP S4967.Which Wix filter ? Have usrd in the past and had severe leaking from around seal.I have the 708cc engine.
