Thank you for all the advice Mad Mackie. I appreciate the thought and time you put into this for me. I was originally interested in the enclosed trailer to begin with and my girl friend and father talked me into getting the open trailer. This is not by any means the first time I have towed or backed a trailer. However, this is the first time I will actually own my very own and tow it fairly regular. I still have some thinking to do. Because before this post I was definitely leaning towards the open trailer and now I am leaning back towards the enclosed trailer.
If I pick an open trailer I will need to install a trimmer rack and a couple garage door springs to help me open and close the gate. If I get an enclosed trailer I will only require a simpler trimmer rack to be installed at first. The dealer that has been very patient with me has agreed to drop off the Ferris and Hustler on Monday or Tuesday. I am going to try them out on a couple of my customers yards, but will not be able to mow with them. Just get a feel for how they act on the steep slopes. If I make a decision they are going to leave the one I choose here.
I told the dealer that I was very unhappy with the seat on the Ferris, and he said it was no problem he could install a much nicer seat for a few hundred more dollars. This is well worth it to me. I still do not like how the Ferris seat has so much play in it. Also I am not talking about the actually seat either, as I am sure the new $500.00 seat will do the trick there. It is how the seat is attached to the mower. It sits on a sheet of metal and does not have anything securing it near your buttocks. For a machine that is so expensive with such a powerful engine, great suspension system, and well manufactured commercial deck, this seat is unacceptable. Right now I only weigh around 135lbs-140lbs. It sorta feels like a larger @$$ would hold it down better. As mentioned before while I was testing it out, it stalled for a quick second because my buttocks lifted up some. I am certain that if I had some more "@$$" I would be fine. However, I am lacking this @$$.
So I will try them out Monday or Tuesday when they arrive and hopefully get back here with some pictures and feedback. I guess I really want the Ferris to work out because I do believe it is the better equipped machine between these two machines I am picking out. However, if the Hustler does better on the hills or feels more comfortable I just might go with it because of the cost and obviously is better in one aspect whereas the Ferris should be at least slightly better all around. If I cannot feel at least a slight advantage while riding on the Ferris I think it will be a difficult decision...
