Blades Fast Attach Blade System Problem
scruffythejanitor
I don't have experience with the S blades, but from what I've heard they're more expensive. Anything's got to be better than the Fast Attach though. I'm going to try these spindles and star blades this season and see how it goes. I have automotive tools including an impact wrench so pulling off the 5/8" nuts isn't a big deal. I can see why someone who doesn't have the tooling might have trouble taking the blades off for sharpening, but for me these will be significantly easier than the Fast Attach.
Even the spindles with S hole that are not the Fast Attach system uses the same 5/8-18 flange nut as the spindles with the six point star blades. The only difference is that an additional flat washer .635X1.585X.062 is used.
But note there are Small S and Large S blades.
scruffythejanitor
Heh -- the wonderful thing about standards is that there are so many to choose from.
Thanks for the additional info. It's nice to have it all in one place for anyone searching for it.
But I do admit the older style spindles will be a cheaper conversion as they do have after markets available for them where the new "S" style yet to have any after markets available.
And it the same with the Husqvarna tool-less blade system. Just cheaper to convert than the parts that are required the repair that system.
Dogjaw
While I'm waiting on a new transmission for my XT2 SLX50 Fab, I just replaced the fast attach spindles and blades with a kit that has a 6 point center hole from 8tenparts.com I was tired of pulling the deck off, flipping it upside down, and beating the collars with a mallet to get the blades off. While I can't mow yet, here's my take so far. My Cub spindle sheaves are 5" dia., and the 8ten are the same diameter. The height is exactly the same. The bolt hole pattern is exact. You'll need a 10mm to remove the Cub spindles, and a 1/2" to install the 8ten. I matched up the new blades with my high lift blades, and are the same length. A big difference is the 8ten blades are thicker and have a 1" longer cutting edge at each end than the OME Cub blades. The only downside is that they don't supply the 5/8"-18 nuts for the blades. I emailed them (got a response within 2 hours on Sunday) asking if the spindles were pre-greased (they are) and suggested they add a few bucks to the price and supply the nuts. Customer service was passing the suggestion on to their product folks, so that may no be an issue sometime in the future. The website was easy to use. Pick equipment type, make, and model. The price isn't much more than a set of the S pattern blades.
Here's what I ordered for MY 50" deck. https://8tenparts.com/products/8ten-mk1002313
