I just noticed this today after mowing a lawn. There is a crack in the transmission case and oil leaked down the case.
I wondering how this could have happened because it looks like something inside the transmission pushed out on the case and cracked it because the cracked metal is pushed out.
I will remove the top part of the case tomorrow and tap the metal flush against the case (hopefully without breaking off the cracked piece. I'll then apply some jb weld inside the case. I'm assuming I can remove the pressure switch and add some more oil. Anyone know what kind of oil it takes. It was like mud coming down the side of the tranny.
Any ideas what could have caused this?
Thanks,
slash
Thanks,
slash
