Check:
spark
fuel delivery at carb
adjust valves
clean engine block and cooling fins YEARLY. This is in your engine manual.
engine over 5 years old, de-carbonize the cylinder, head and valves. Again in your engine manual.
water in the fuel
compression
clean carb again, inside of the body and jets/emulsion tube helps too
choke working properly?
plugged air filter
clean and flush out fuel tank and install new fuel line
Spark is good(rund on anything you spray in it)
Fuel delivery is good(new pump,filter,fuel)
I dont think we are into adjusting the valves yet as it does fun just fine just wont get fuel
Mower is emaculatly clean. She uses about twice a month in mowing season and cleans it after every use.
mower is not ever 3 years old yet
No water is fuel as it is new fuel i pumped myself
Compression is fine(it runs)
Carb was in great shape when i pulled it apart. I was under the impression she ran out of fuel so i did filer new fuel and pulled the carb and cleaned out all the needles jets and passageways for the fuel in anticipation of trash being in there somewhere.
choke works fine
Filer its fine. No difference with it out
