Excessive crankcase pressure on 19.5 briggs oppy?
Scrubcadet10
Moderator
Staff member
Maybe...but she's using oil pretty badly and smoking and it sgrugg,struggles, to Rev up from idle and it'll try to ztall when quickly putting it at idle
Could be running bad from too much fuel....
That’s my best guess, hopefully you’ll prove me wrong. Please let us know what you find.
hlw49
Also before this it only said that happens to OHV while this is a flathead motor but I'm not positive on that
you know if you were to post the model type and code # it would cut out a lot of the guess work.
hlw49
That carb has the fuel pump built into the carb. and the diaphragm could have a hole in it drawing fuel into the crank case. Did you change the oil? It could be too thin and getting past the rings and causing it to smoke and use oil. It could also be the crank case breather blowing oil into the carb. through the breather tube.
STEVES
1st - fix carb
2nd - change oil
