- Sep 24, 2017
- Threads
- 284
- 6,844
Could be running bad from too much fuel....Maybe...but she's using oil pretty badly and smoking and it sgrugg,struggles, to Rev up from idle and it'll try to ztall when quickly putting it at idle
Could be running
Hmm maybe but I this it's definitely more criticalCould be running bad from too much fuel....
you know if you were to post the model type and code # it would cut out a lot of the guess work.Also before this it only said that happens to OHV while this is a flathead motor but I'm not positive on that
Mkyou know if you were to post the model type and code # it would cut out a lot of the guess
It's a 42E707-2275 code is 0106085Ayou know if you were to post the model type and code # it would cut out a lot of the guess work.
