Issue of using 87 octane is unresolved? Maybe not for you but it is for me.
Fine- your choice/decision. A few posts swearing by 93 is not evidence for me. The true power of knowledge is knowing that you dont know.
Thanks. But this "top tier" thing- hate to say it, but Im very suspicious about top tier concept. All gas in a specified octane is the same(except for the added ethanol), comes from the same pipeline from Texas, ends up in southeast, and one way up in NJ somewhare. All trucks fill up at the terminals, and then they "brand" it.
Still, my manual says use 87 octane, so why should I use 93? Like using 93 octane in a car that specifies 87. Roads are full of people puting in 93 octane "high test" , when they are doing nothing "better" to their cars even though their cars specify 87.
all posts appreciated, as the more the better.
Every flame has a unique flame temperatureWould you explain " burns hotter " .
Arent the fuel filters on these mowers filtering out some of the water in the fuel? Also wouldn't running some carb/fuel injector cleaner in the fuel occasionally help prevent any sludge or gum deposits?
Also on the 93 vs 87 Debate. Some of the brands of 93 out there have some added detergents in the higher tier fuel. Not sure if it matters much but I know shell is supposed to have some cleaning agents in their 93 octane which is like running injector cleaner in the tank. I can't specify on a small engine if it matters much though.
Agreed, a 40 mic filter will stop water for around $8. But then that causes more probs unless you change/ empty the filter often. Normally if an engine is used often the water prob takes care of it's self simply cause the fuel that you have in your can is fresher.The Fuel Filters you'll find on mowers are not going to filter out water. there basically nothing more than rock catchers as we used to call them. They do make filters that will separate water from gas but there super expensive and I don't really think they make them for a lawn mower engine. If you use a good quality fuel like the Shell gas you should have to worry about water.
